Is everybody here aware that the jet in carby is replaceable? By chance I discovered that Dellorto PHBG main jets are a perfect fit! The 70cc's really need a bigger jet. I am using an 0.85mm jet which compares to 0.70-something for the stock. I raised the pin clip to the highest (leanest setting) and then dropped it back by a 1/2 using a tiny washer.
That is another great tip: To get an in-between clip setting simply use a tiny washer.
Bigger jet is a massive improvement with the leaner clip setting needed for compensation. Now my engine is very smooth during the mid range and no longer starves for fuel at full throttle. I feel that idle may be a little lean however because it idles very high now.
Dellorto PHBG jets are cheap mine cost $5.
