I had the Worksman outside today so I took some better pictures. First paper mock-up of the oil tank/tool box. Also built up a nicely ported custom intake manifold.
I just went and looked at your set-up (I saved a couple shots of your bike). I have been using the front mounts as is on these engines and then run two rear mounts stacked up. If the sprocket interfers with the engine then I add spacers under the the first rear mount where it meets the engine. By doing this I can move the front mount up the front drop tube till I clear the sprocket. I also use this method to get the chain size I need. I will try the 36t first in this fashion and then use the 32t as a way out if the 36 does not work. Do you think that will work?I removed the chain gaurd brackets also but wasn't able to fit the motor down on the tube (like you have it) with the 36T.
I make the bike stands. If you need one just shoot me an email. I can even kick start the bike (not this one but the finished one!) on the stand and then let it warm up. This stand has the Schwinn "AS" logo above the motorbike logo, but that can easily be dropped from the CAD file if you don't have a Schwinn.Your wheel holder looks great with your classic build can I ask were you got it?
Nice looking all the way around!
Steve.
Sounds like it would work!! I am using the stock intake and clearence for the throttle cable is veryclose. A 32 may be helpful on my application. I don't have to means to fabricate parts like the intake or muffler so I have to go with what works.
You say your using two mounts in the rear... have you seen these?
Gas Powered Engine for Bicycle 3 Inch Rear Xl Motor Mount With Studs | Motor Mounts | Parts for Gas Powered Bicycle Motor Kits | Live Fast Motors - Gas Motorized Bicycles and Gas Motorized Bicycle Parts
They can be cut to the size needed.
Hi Sential,so i'm a little confused, is the loop frame from worksman available yet?
