kbot6789
ok guys this is the howto part 1 ....... take two parts distillle vinager to 1 part  hydrogen peroxide=== example  2 cups vinager to one cup of peroxide  mix well <-- thats jkust a guidline to go buy you can mix up as much as you need oh to this one cup mixture ad one table spoon of salt stir well .. if you need more then that mix more up but here is what you do after you mix this solution up use a piece of nickle for plating... now rememember are are not ready to plate just yet.... find a old dc power supply i used a old atx power supply from a computer here is the  wireing cod if your gonna use it its 12 volts works great the yellow wires are 12 volt the black are ground wires in order to turn it on snip out a black ground wireany black wire  and twist it with a green  wire ...  now take a piece of nickle and hook it to the yellow wire witch is your + and take like a piece of old  metel.. remember we are makin the solution  to plate not plating just yet   i used just a  steel nail as my negative   not take the nickle  thats on the + now immers the nickle under the solution leaving the conntection to the nickle above the vinager line take the other the nail or what ever your gonna use as a negative electrode its fine if it get submerged fully  because the negative draw the metel ions throught the vinager  anyways turn your powersupply on let it sit for about 4 hours till the vinager turns a color just a little lighter then coffee this is your solution to plate with
strain it with a coffee filter and your done making the solution
 oh one more thing this does produce hydrogen gas so please do this outside your home not inside and since its hydrogen gas please no smoking .. i do love to hear from you guys  so please be safe oh almost forgot never let your parts and the positive plus nickle touch keep them seperated under the solution
more then welcome gearnut i tried to make the instructions as simple and easy as i could so hope you guys understand them if you got anyquestions just  post em thanks and enjoy guys
