TheOtherStyle
I've never seen one this old before...
Style, Oh My God!!! Thank You, Thank You!!! I Never Dreamed I Would See Those Pic`s!! 59 Yrs Ago The Nabor Guy Helped Me Build A Motor Bike With That Motor!! The Gas Tank Is In The Bottom Cast Iron Base. There Is A Metal Pan The Sits Between The Base And The Block For The Oil. The Intake Valve Is A Poppet Valve. It Has A Soft Spring With Out A Rocker Arm, The Vaccumn Sucks It Open On The Intake Stroke. It Has The External Exhaust Push Rod And Rocker Arm. Always Remember It As A 3/4 Hp B&s. Cost 4 Pennies To Fill It Up. Paid 25 Cents For The Motor From An Older Kid. Left My Pocket Watch For Security And Was To Pay Him On Friday Eve At His House. Friday He Was Not Around. Sat I Went To Pay Him, We Had A Simple Contract To Pay On Friday! He Kept My Watch. That Still Bugs Me. The Bike Frame, We Cut The Bottom Bracket Out, Bent The Seat Tube Back And The Head Tube For Ward For Engine Room. Welded In A Offset Plate For The Motor. Bought A Whizzer Large Rear Wheel Pulley And Run It Direct Belt Drive. The Carb Is Bolted To Gas Tank With The Long Intake Tube. Did Not Have Air Filter On Top Of Air Tube, Put Your Thumb On Top Of The Air Tube To Choke Engine And Push To Start And Jump On. No Muffler, Just A Piece Of Pipe About 4 Inches Long. There Was A Nice Blue Flame To Be Seen At Nite! Had A Angle Iron Bolted Accross, Under The Engine For Foot Rest`s. No Throttle, It Ran Full Throttle. It Had A Kill Button On The Air Shroud To Slow It Down For Corners Etc, No Pedals, No Brakes Or Fenders. Was Only 11 Yrs Old. Let My Friend Ride/drive It, He Came Down A Hill And Had To Turn Corner Going Too Fast, Went Thru A Flower And Then Veg Garden, Looked Like A Large Tossed Salad!! Lol. We Got Heat Over That. This Was In Eau Claire, Wisconsin. That Winter I Mounted The Motor And Wheel On An A Frame Type Of Triangle With A Pivot, On The Back Of A Metal Runner Snow Sled. The Plan Was To Run On The Hard Packed Snow Roads Of Those Days. The Motor Bike Belt Was Too Long, So I Went Around The Pulleys With Several Wrap`s Of Hay Bale Twine!! Bad, Bad Idea!!! I Had The Wheel Blocked Up Off The Ground.the Twine Belt Came Off, I Tried Putting It Back On With Motor Running, O U C H! 3 Finger`s Got Caught And Wrapped Into Motor Pulley. I Had To Jerk My Finger`s Out To Keep My Hand From Screwing Off!! Broke 1 Finger And Tore The Hide Off Three. When My Hand Healed Winter Was Over. Sorry For The Rant. I Can Still Smell The Exhaust And The Dirt Roads/trails. I Never Sniffed Gas Or Paint Etc, But Gas Smelled Good To A Motor Nut In Those Days, Sure Stinks Now. Ron
Try this Antique Hit and Miss Stationary Engines Gas Gasoline Steam and Diesel Then go to small engines and you will see an interesting bunch of old iron of every description.
These motors do show up every so often.
Steve.
Steve.
Cam
i remember my grand mother and her 2 stroke maytag washer. Had an oily flex pipe. The pipe went outside of the laundry building. They must have had enough oil in the mix, i remember the blue smoke !! Lol
curtis
i can`t remember where the briggs went (to heaven i hope!!). You got a model a, so did i ! Bought it for $35. On pymts when i was 13. Mine was a 1928 coupe. It had the canvas down below the back window. Also the shorter fatter radiator.
I remember one nite there was 13 of us riding in it at once. It had the rumble seat with the reverse trunk lid. The tires were looking like they would blow.
When i was 15 , traded the model a for a 1936 harley 80 cubic inch flat head. When 16 and got my drivers lic, bought a like new 1949 harley 74 ci fl = 1955.
About this time also had a 1936 ford coupe convertible with a rumble seat in the trunk, paid $20. For it. Rare car now. 59 years without a mab!! Lol.
Just finished my axle mount. Took the electric cartridge motor off a electric bike and installed a 49cc 2 stroke. Have freewheel on axle. Works super !! " n o y o u do n o t f e e l t h e m o t o r " lol.
Clocked it at 35 mph in first run. PIC`S ARE IN "MINNESOTA LAWS" THE FORUM WILL NOT LET ME RE-POST THEM.
RON
Ron .![]()
