Andyinchville1
Manufacturer/Dealer
HI All,
In reading posts that expressed a concern over the current 9 hole mounting system for the sprocket (mainly addressing the issue of spoke breakage and /or obtaining a precision alignment of the sprocket itself), I was wondering why nobody makes a high quality hub that a sprocket can directly bolt up to....
I do realize that Grubee (I think) sells a hub that this can be done BUT it is really not suitable for a multi speed rear casette / freewheel and it probably isn't of real high quality anyways (like a true high end bike part...Say for instance Shimano Dura Ace...etc...).
I was wondering if it would be worthwhile to take a hub designed for a disc brake and mount our sprocket onto it in place of the disc...This would not only provide a good spoke free mounting area for our sprockets BUT also give us a high quality, readily available, hub with multi speed capability and perfect sprocket centering / alignment (not necessarily chain line alignment but the sprocket would have no wobble or be out of true). Chain line alignment can be handled by a sprocket offset, dishing the wheel etc...Sprockets would also be able to be changed out with great speed since alignment and centering issues
would become a moot point.
Any thoughts or ideas on this?....Is the mounting area of a disc brake set up strong enough? ( I think the bolt holes are smaller and fewer but maybe high strength grade 8 could be used?)...Any experimenters out there? ;-)
Andrew
PS - Since this post was originally made, Our Custom Sprockets are now available drilled in a dual pattern ( one set of holes to accommodate the original HD 9 hole mount and another set to accommodate the 6 Bolt IS standard for mounting the sprocket in place of the rotor on a disc brake type hub. The bolts needed for mounting a sprocket in place of a disc are said to be M8 x 15.....Any testers out there?.....The original customer that was going to try the prototype ended up having bike issues and was not able to accomplish the test.
Andrew
