holy crap, I have never seen anything like that before. That's crazy.HI,
For quiet you can do this.....Large volume muffler means zilch back pressure for all practical purposes....Quiet too!
Andrew
Andrew
its all good to do this but the engine will still need back pressure otherwise it will probably seaze, a good way of doing a performance mod would be to rip the guts out of the muffler and drill holes in the end cap, or make a new end capI ran my "Bomber" Bike like this!!!
They are really fast & powerful without the baffle!!!!
It won't hurt it running it like that.
The best compromise is to drill a few 3/8" holes in the end of the baffle. (A little more power, a little more noise!)
Isn't that what I said?????a good way of doing a performance mod would be to rip the guts out of the muffler and drill holes in the end cap, or make a new end cap
The bike will be fine. Gas back pressure isn't much needed it's the back wall to reflect the sonic wave and a front wall to compress it to supercharge the cylinder so ride on man and have fun!
is there anyway to get the sound and the speed while still keeping the throttle response?It doesn't remove all backpressure. A two stroke will run without a muffler, it's just hard to get good throttle response from off idle to upper midrange..
I was looking at one of these stock mufflers The other day. When you removed the baffle do you mean all the internal guts? I want to completely remove all the inside of one thats going on the end of the tuned pipe on my Morini motor. Last repack the cavity with steel Brillo padding for Quieter noise pollution. Just wondering what is termed as the baffle? I am baffled by all the baffling I see inside? If so how did you get the guts out?When I removed the baffle from my first engine I could hardly tell any difference when run side by side with a "stock" muffler.
Any little muffler shop can reweld it in 1 minute... (& probably for free!!)I want to gut my muffler now, I just don't want to have to re-weld the end cap back on
