$2 front mount fix for cruiser frames
joek
made it this morning out of a $2 hockey-puck and the stock mount in the BGF kit. engine is aligned and rock solid. FWIW Joe
[/URL][/IMG]
[/URL][/IMG]
It does not show well in the photo, but the steel adapter plate in the photo is modified. put it in a large vise and used a BFH and a block of wood to bend it lengthwise to match the angle of the down tube.
Hmmmm..... Use a hole saw to cut the hole in the puck for the frame tube. Use a hack saw to rough shape the outside of it. Finish the outside up with sandpaper.
This sounds doable to me.
Thankyou for sharing your example! Now I know how I am going to do the front mount on mine.
[/URL][/IMG]
[/URL][/IMG]
That is simply a BRILLIANT idea. There is nothing better than using a common
item and convert it to such a unique application. I wish I had thought of that!
I spent many frustrating hours trying to figure out a way to rubber mount mine.
I tried all kinds of plumbing parts front end bushings etc., I have a bag of hockey pucks from years of coaching and never gave them a thought. I'm very
impressed. I'm gonna make one this week.
I used a forstner bit, I think a hole saw would bind and overheat in a flexible material. fwiw Joe
Good point. I have no Forstner bits, but I bet a spade (paddle) bit would work out too.
Thank you for the heads up!
Joek, How many time have been in a hardware store looking for something that you will not use for its original purpose? Probably like me, often. Great adaptation, you get my vote for the 2009 MB Jerry-Rig Award
The hockey puck method will save me alot of blood, sweat, tears and time! Thanks for a good tip! Will put up a pic when I'm done, need another puck for mount number two!
Here is my version of your idea in a progress. I put longer rods on the block and then drilled and sawed a puck. This idea worked good for me trying to raise the motor on a V-frame due to clearance probs.
Here are the pics!
A hole saw will work if you keep the cut oiled. I used that method to cut some chunks of rubber to make engine mounts for a Rotax in my Avid Flyer. It tends to be a bit sloppy but a ring of aluminum foil around the rubber keeps most of the oil and rubber dust contained. I have forstner bits so I'll get a couple pucks and try that for my next bike conversion.
He's my hokey puck hack.
this is a very simple idea! i tried explaining something like this to a firend when he first did his motored bike over a year ago.. use some sort of damper! he has stacks of tubing for spacing lol
anyone every tried a sway bar mount for a car?? swaybar mounts are already round, and have a slot. im a mechanic and have seen many different sizes, rubber material etc..
Now that is a darn good idea! It would probably cost more that a hocky puck mod, but it would be ready to install right out of the box. Now if we only could get a listing of the part numbers listed by the various hole diameters. Anyone here know someone who works at an O-Riley's with alot of free time?
