5-7
HELLO.
Most all of the pocket bike/scooter tranny`s have the six spline for external sprockets. There is a 12 tooth six spline sprocket with 1/2" pitch for bmx chain, have one on my diy axle mount build with the 5:1 box.
The single chain 3:1 tranny has a front #25 sprocket the size of a dime!! Like on the pocket bike clutch housing.
Dax chain box has the six spline that is longer for , apparently for better rear chain alignment!?
The dual #25 chain box is wider.
The cogged belt drive from "bicycle-engines.com" would be good for $139. but you need an engine with a straight 5/8" crankshaft. There was a model of it that fit all the engines with the 76/78mm clutch system for $10. less, but is only in their kits currently.
Terry Blow had them in Canada, but is shut down for a few more months.
Quenton Gunter may have a Q-matic for the 76/78mm clutch, was talking of it, but would be wider than the regular Q-matic unit.
A 5:1 box could be used with the 12 tooth 1/2" pitch for bmx bicycle chain, then use a 5 hole freewheel sprocket adapter on the back wheel`s right side.
With a wheel threaded on both side`s, a South-paw (left hand thread) sprocket could go on the left side of rear wheel for pedal power, put pedal chain ring on left side and run the 5:1 drive to single free wheel sprocket on right hand side of rear wheel. Imho a spring tensioner should be used when ever possible, prevents problems. Whew, need a nap now!! lol.
Ron ...
![cvlt1 cvlt1 cvlt1](https://motorbicycling.com/images/smilies/cvlt1.gif)
