Norman
LORD VADER Moderator
Got the new wire today #28 and #36 gage so I jumped on the winder.
Makes a big difference with good new wire didn't break it once. I was sweating
that #36 gage I've broke more of that than I care to think about.
While waiting on the wire I tried some splicing I didn't like the small ball
the wire made by welding it together with a bic lighter so I practiced
soldering it got it to look real good so thats the way I'll do it from now on
made a little jig to hold the wire in whats the reason I was having trouble
trying to solder it.
Got a couple of photos of the winding of the coil
all done with the winding 3601 turns of 36 gage wire went on there.
this the ohms reading on the fine(blue wire) you can't see the coil very well
in the next 2 photos but it covered with masking tape and the wires are soldered on.
If this coil works good I'll wrap it with a string covering and may coat the string
with epoxy.
reading on the 28 gage wire (white wire) there was 5 rows with 389 turns total. I insulated each winding row from the next layer. I put on too much 28 gage the ohms should read around 2.0 to 2.20 ohms and no more. Sooo I had to unwind the whole thing and get the heavy wire reading down to 2.0 ohms. the engine will run on it like it is but the lights won't work right. they are very dim
one more shot of the coil I tested it then unwound it to fix too many turns of 28 gage wire. Using the new wire made this so much more easier.
with epoxy.
