I already did an weight comparison and here it is.
OK weight measurements (Steel pin + Needle Bearing = 20 grams) --- (Steel pin + Bronze Bushing = 24 grams) --- (Steel pin + Aluminum Bushing = 16 grams) --- (Titanium pin + Needle Bearing = 12 grams) --- (Titanium pin + Bronze Bushing = 18 grams) --- (Titanium pin + Aluminum Bushing = 10 grams) --- (Titanium pin = 8 grams) --- (Steel pin = 14 grams) --- ( Needle Bearing = 4-6 grams depending on bearing) --- (Bronze Bushing = 10 grams) --- (Aluminum Bushing = 2 grams)
There are only 2 grams to be saved between titanium pin with bronze bushing and Steel pin and quality needle bearing in my weight test.
Not enough to make any noticeable difference in my opinion.
Map
Ya I read some stuff on the older juice moto bushings and it was no good. The reason I wanted a bushing was to lighten up, for less vib. I ended up getting a new needle bearing, pin, piston and rings, clips and a nu cylinder. Basically a nu top end from piston bike for 88.00.the cylinder was worn out. I need to pick up a jetpack cdi. That's all I can afford right now.anyone know where I can pick one up??
I'm not familiar with HD can you give me the address?
