It really depends on how hard it is to get to the common ground points for the windings, Jason.
It's not feasible to isolate the ignition winding. Number 1, it has to fire the plug, which is grounded. It would be nice to isolate that but since the CDI is potted, we can't go in to add a separate ground for the input.
If we isolate the ground for the lights, all the lights would have to be insulated. That's fine for purpose built lights, but eliminates the standard one wire connection bicycle lights.
I can't remember all the transformer theory I learned in the 60's. I don't know how much effect the mod I'm thinking of will affect the existing windings.
I've checked the ends of the mag pickup. There is plenty of flux available for another winding. I'm gonna take a ] shaped iron bar to connect the ends of the legs. The short legs of the ] should move the long side back far enough to wind a few hundred turns of wire on it.
Then remove the pickup, remove the varnish from the ends of the legs and stick it to the pickup with a drop of superglue on each leg for testing. If it works then pull it back out to glue it properly.
If that works (voltage and current wise) we're still left with interaction with the ignition windings if we ground one side.
A one-to one isolation transformer may or may not solve the interaction.
I'm going to order another magneto. I don't know if I'll be able to keep all the smoke in mine.
Where are all the Double Eagles on this forum?
Ted
Ted: can you determine the output votage of the secondary coil, the blue wire, or make an educated guess?
I had deducted 72V just based on the number of windings and using the other coil as a reference based on 300 turns @ 6V. If it's working as a true automotive type coil, (coil in coil), the voltage will be much higher.
Jim
It doesn't work like an ignition coil. The ignition coil depends on a voltage on the primary (low number of turns in this case) building a flux and then when the voltage is suddenly removed the collapsing flux through the windings of the secondary (high number of turns) inducing a very high voltage.
The coils on the pickup have relatively slow rising and falling voltages. Slow compared to a points coil; fast compared to 110VAC.
Our ignition coil, I think, is in the CDI. The output transformer in the CDI steps up our ~72V to 20,000 or so volts. It has a much more favorable step-up ratio to deal with.
I think right now our best bet is to leave the white wire alone and try adding an auxiliary coil. Then we can play with injecting a voltage in the white wire to stroke the CDI. I'd be surprised if we could go very high without smoking it.
I couldn't get to town today so the scope is still just looking at me like it wants to go outside for a walk.
Ted
Jim, I hope you guys get this figured out. I have an instument panel all wired up on my winter build with headlight and tail light wired through the white wire and switches. According to continuity everything is good but I haven't fired it up yet. I am using l.e.d.'s so I thought I would be o.k. but a better, or 12 volt system would be the ticket.
Thanks John
Yes a tail light Too!
Jim
We'll sure give it a try...as you know for the most part anything "can" be done it's just a matter of cost. I'm hoping the outcome will be an inexpensive replacement coil assembly that can simply be bolted on for added elctrical power.
l.e.d.'s are not power hogs, so you should be fine! I really don't know how much current you can tap from the White wire before there is a problem with the ignition. Apparently it's not much!
Jim
whatever happened with the setup up norman was selling, did it work what for bulbs did he use
