whistling motor
Discussion in 'Motorized Bicycle General Discussion' started by beentryin, May 9, 2010.
  1. beentryin
    beentryin New Member
    Apr 24, 2010
    208
    i ran my motor about 20 miles today brought it home and took it out about 3 hours later.and it has a whislte to it sounds like its coming from the clutch
  2. CoastalCruiser
    CoastalCruiser New Member
    Apr 28, 2010
    338
    Intake manifold leak perhaps?
  3. psprat496
    psprat496 New Member
    Nov 22, 2009
    161
    I notice these same sounds as well. It's not the clutch gears but when I travel at higher speeds the engine "whistles" loudly. Is this really the sound of an air leak?
  4. Mac
    Mac New Member
    Dec 3, 2009
    489
    One of my PK80's devoloped a "whistle" after about 100 miles, more of a gear "Howl", looked it over, the keyway on the small pinion gear seemed to be jammed up, removed the loc screw, used a bit of loc-tight{blue), put a new keyway on, has not been back since. Hope that helps.
    Mac
  5. metalliatic
    metalliatic New Member
    Mar 14, 2010
    96
    mine really screams. i have a bigger intake, carb, and expanssion chamber exaust, with a billet head. i think it might just be the air being sucked in to the carb.
  6. beentryin
    Apr 24, 2010
    208
    no this is at idle and if i pull my clutch in real tight it goes away
  7. psprat496
    Nov 22, 2009
    161
    Oh, we'll that's most likely the sound of your clutch engaging. When you pull your clutch is it easily pulled or stiff?
  8. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Did you put a finger tip size dolop of grease on the small gear that drives the clutch gear?(inside the clutch cover)
  9. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Could the clutch pin and ball need lube or be starting to touch the release lever?
  10. metalliatic
    Mar 14, 2010
    96
    mine does it at high rpms
  11. beentryin
    Apr 24, 2010
    208
    its alway been kinda stiff,but its a smooth stiiff if you know wat i mean.i greased the small gear a few days ago,do i just pull the bar out and put grease on it?
  12. demac
    demac New Member
    Mar 8, 2010
    97
    it honestly just sounds like the clutch cover, where the gears are located. trying holding your hand on it, hear it that dampens the vibration. You can buy a cover that dampens the noise and wont hear a screech or whistle. ""sickbikeparts"" pretty sure.
  13. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Yes ,just a mild greasing ,all over it............Idle was why I thought of the bucking bar and ball ,under the cover w/the clutch lever in the center of the drive gear,,,a clutch cover damper (above) sounds good too.......If it doesn't stop,you might try small squirts of WD-40 where the intake manifold bolts on,, and carb. conector,etc looking fot a whistling air leak.
