Elaia_Lychnia
If I purchased a lower cost bike from a place like Chubby's Bikes online and wanted to change the wheel set - and put a motor on the bike. Which type of wheel set would you recommend I go with?
Husky makes a lot of good wheels. You can get them through their industrial bike site or pirate cycles has them also. Stick with the Shimano Coaster rear hub and get an adapter with sprocket and your good to go. Also Husky has a front wheel with drum brake, also a good addition, stop is just as important as go, lol. L8R.
The Firmstrong doesn't list what gauge the spokes are but my preference is to have no less than 11ga on the rear and no less that 12ga (preferably 11ga) on the front. The problem is that the rear hub may or may not allow you to mount a sprocket adapter later but you can use the rag joint that is in the kit for now if you wish. as I agree with the others to use a Shimano (CBE-110) as it is the most standard of all of the rear hubs to fit sprocket adapters which make your life so much easier and your ride so much smoother. I have used both makers designs of sprocket adapter and personally like Sports Car Pats design for several reasons. Just an opinion though. I like the Sturmy Archer and Worksman Hubs and wheels both for the front.
Elaia you are never REQUIRED to do anything but be prepared to get many opinions when you ask for help here. Diversity is good and this is a diverse community and seems like not many people agree all of the time but in the end it is your decision and it is you and your wallet that has to make that decision.
