fatdaddy
Spark plug problem I got it running without deadswitch couldn't shut it off so pulled spark plug wire now won't start checked for spark there's none is spark plug cdi bad ?
So, ya disconnected the kill switch, got it running, pulled the plug wire to stop it, now it wont start again. did I get all of that right?
FIRST, make sure the wire is still screwed in tight to the CDI box. Then check the plug boot to see if it came apart inside when ya yanked it off the plug. next thing is to check yer coil. but check the easy stuff first. since you were yanking around on the plug wire, I'd look at that first.
fatdaddy.
