whats the proper gas/oil mixture ?
Mannhouse51
Hi everyone. I have a wildfire 49cc bike. The manual I downloaded from wildfire says the first gallon use 32:1 , then use 50:1 after that. Thats sure seems like an awful small amount of oil. (I'm still using 32:1 and bike runs nice.) Any input is appreciated , Thanks!
If you are running reg. 2 cycle oil 32 to 1 is ok if you like the results. If you go to 50 to 1 it would be best to go with the best synthetic oil for air cooled engines you can find.
You can't go wrong with 32:1. You also have some folks who say the same about running 100:1 on their bikes using optipube oil.
optipube?
I thought this was a family oriented forum!
I recommend 20-1 for break in and 32-1 thereafter if you are using regular dino oil.
Synthetics I run at 32-1 too.
Opti2 can be run at 100-1 due to it's unique formulation. There are alot of folks that will absolutely not trust such a thin oil ratio like that and like to scoff at such a ratio.
In the end, run what you feel comfortable with, and never mix it thinner than what the oil manufacturer recommends.
