deacon
minor bike philosopher
Okay
I have used weed whackers previously as friction drive motors. I had less than perfect results due to vibration problems. But that is not todays question.
I plan to build a DIY generator using a scooter motor, as a generator, a #25 chain, and a weed whacker engine. I plan to mount them both together. I am first going to try doing it eliminating the batteries completely. Run the electric drive of the bike directly from the generator. I read that diesel locomotives do not run from the diesel engine. That engine turns a generator which powers an electric motor. The reason is so that the power can be applied to the drive wheels more precisely than any clutch could. If I can make this thing work, there would be no need for shifters or gears. You do not need them on an ebike if it has enough power. If I can't get it consistant enough then I can at least charge the batteries while I ride to increase the range a bit.
For it to work even a little consistently I need the weed whacker to turn the motor at pretty much the same speed all the time. I'm not sure that a weed whacker is capable of that for say thirty minutes at a time.
I don't think turning the scooter motor will be much more strain than turning the cutting head in a weedy lot. However I wanted to get your opinions.
http://i36.tinypic.com/15pk605.jpg
I was at wallymart this morning and found a 25cc blower for 68bucks. I wonder if that will turn the scooter motor fast enough. I wont need a clutch but maybe an electrical switch to interrupt the current flow to the bike motor.
