mew905
Hey guys, I know it's been discussed time and time again but apparently there actually is something to the turbo on a two stroke. 4 strokes lose some power due to the valve system and restricted exhaust, netting usually at most around 100% extra power, depending on the size of the turbo.
However the argument against two strokes and a turbo is it'll blow air right through the chamber. Would make sense, even without the turbo though it blows your intake charge straight through, at least it would if it werent for the backpressure in your exhaust. Also the pressurized oil and lag from the size.
However what if I proposed to you that you CAN actually turbo a 2-stroke, and it nets between 2-4x the power? No, it wont blow through as much as you think. The turbo, being dependent on the exhaust pressures, also introduces its own backpressure. Being that two strokes love backpressure, this is a gain, not a loss, and the fact that it spins makes it adjustable too. From what I can make out, you jet up when you increase your compression to counter the blow through from the extra pressure anyway, which would mean your expansion chamber length would be different, which the turbo literally naturally adjusts for. The faster exhaust comes out, the more the turbo is going to pump in, and start the process again, more compression, bigger bang, more pressure meets restriction, turbo spins faster, so on...
This may not have been tried on our HT's yet but it has been done on drag snowmobiles, outboard motors and scooters, all two strokers. The gain is huge on a two stroke in general but because our motors have such tiny intakes, breathing is an issue, a turbo would overcome that. I imagine we could net 3x the power currently available in our motors via a turbo, provided we can cool them and get oil flow in the turbo. I'd say drill a hole in the crank case and run it to the turbo to share oil but having gasoline mixed in and knowing the temps turbos can reach, that'd be an inherently bad idea. There is a 40mm turbo available for $1000 or a china clone for $450, from what I recall it does have a sealed bearing system (dont quote me on this), perhaps may be worth a shot.
I know I'll definitely be looking into it, however as we all know, reliability will most likely be an issue, so perhaps a race-only motor.
