All right, so I have Snow Tiger, my Tanaka-powered Diamondback Response mb.
And I'll have The Blue Twins, my "other one".
I bought the prettier PB engine on Ebay. It was a custom project someone built, but never ran. It has an adjustable carb that I like. I ran it on friction drive for a few miles, then it quit. I think it's the spark, which I'll fix as time progresses.
The plain-Jane pocket bike engine was purchased as a curiosity piece. Both were literally door stops to the shop. They'll finally be put to good use.
The picture of my build is in the General Discussion section. I'm not good in posting pics. My son's coming over to help resize the photos I've taken. Then I'll post 'em.
This is only Day 2 of the twin-engine formatting. The rest of the bike's been slowly coming together, as time and $$ affords.
Basically, it's a frame-up build from a new old stock(NOS) Diamondback frame I found online. In fact, I get most of my parts from Ebay or other Internet vendors. I was happy to find a suspension fork for my 1" headset tube. It's an inexpensive $75 Suntour fork. Three things I need from my bicycles are engines, front suspension forks. And disc brakes, front and rear.
That's just me.
This is how I see my controls' layout on the handlebar:
Starting on the left, a twist throttle on the handlebar, controlling engine #1. That's the powerplant bolted under the top tube. One brake handle is on the left side, which controls both front and rear disc brakes.
Two kill switches will mount near the brake handle. There's one for each engine. Left switch kills engine#1; right switch kills engine #2, which is the powerplant on the bottom.
In the middle of the handlebar will be a simple generic bicycle speedometer. There might be a problem attaching the sensor to the Teny mag wheel. If the speedo doesn't work, it's not a bother. I MIGHT run up to 40mph on occasion, if the speed limit is 35mph.
I just need to get up to speed VERY quickly, lol. That's where twin engines provide the torque to push through stiff headwinds and inclines.
The right side of the handlebar won't be as busy. A twist throttle for engine #2, and a derailleur control for the Shimano 8-speed cassette. It'll probably be the "quick-shifter" Shimano model, like on Snow Tiger.
I like keeping things "same-same" on my bikes. Same 8-speed cassettes and shifter, same brakes, same gearing and sprockets(46.51:1 first gear and 15:1 in 8th gear), same Schwalbe Big Apple tires.
I'd love to run the same Tanaka engines, but they just.....won't.....fit.
![:-|| :-|| :-||](https://motorbicycling.com/images/smilies/Waa.gif)
