I've been running a Predator 212 for over 3-years and have not had problems with the cops in 2-towns. I would say it's because I don'tGo to the DIY forum to find the answers to your question. You will see that this isn't a new idea. I would go with the 99cc too. Actualy I allready have two bikes with 99cc Preddys.
mess with showing the bike of since my engine is far from stock and to keep the noise down use a decent dirt bike muffler on it. While
in town, no horseplay and if in the country it can be turned loose up to 70+ mph. That's risking it since a bicycle frame and tires aren't
made to run motorcycle speeds. No rear suspension is dangerous on country roads so about 35 mph is about maximum to ride at on
that kind of bike. The full-suspension EMopeds are safe at 40 mph but then again, the tires are not made for that speed.
Lighten up Jerry, you are not a Moderator.You posted on a thread that's 13 years old. You also replied to @wayne z who hasn't been on the forum for 3 years now. You should check the thread dates and members Last Seen dates.
No I'm not a moderator but inactive old threads should be primarily for research. When a thread hasn't been active for many years there's a strong probability you won't get any response by posting on it. Should you wish to post on them, it ought to at the very least have an active member still on the forum. If the topic is truly of interest to you, it's better to start your own current thread on the subject rather than trying to resurrect an ancient one.Lighten up Jerry, you are not a Moderator.
Old threads are worth resurrecting.
I have a few motorbikes from 3hp to 8hp and found if you build it right they will perform nicely. The main thing is safety. When you start using higher hp engines you need to add gussets at weak points in the frame, heavy duty tires like Maxxis Hookworms for example, strong front and rear brakes with heavy spokes and hubs, solid seat, front suspension forks, better levers than come with kits, good cables cut to the correct length routed well and clamped down to the frame, solid engine and fuel tank mounts, robust throttle return spring, high quality chains, etc. You basically turn it into a light weight motorcycle like they did over a hundred years ago. Luckily we have better roads, modern light weight engines and high quality components so we can go faster safer. It's like building a hot rod car. The more power, the better everything else needs to be. Some builds took me a year to make everything just right and a lot of the fun is in the R&D and making the bike one of a kind.Has anyone tried an engine like this one? It might be a bit too much for a bicycle. I think it was made more for mini-bikes. Just wondering what you MB vets think.
I agree with you Tom, I like it when someone posts on old threads, and really like when someone replys. Jerry ever thought about you may not get a reply because of your profectinist addatude? seems you got to be right about everything. You have a nice bike, but seems you whant everone else to copy you................CurtLighten up Jerry, you are not a Moderator.
I don't expect anyone to copy me. Unless you have a decent machine shop or at least access to one, the Staton Inc triple chainring double freewheel shift kit hasn't been available to the public for over a decade. David is also shutting down his business that he's had for 42 years. So it would be ridiculous of me to think somebody except a skilled machinist could copy my bike. The reason I display my bike is so people will know why I'm an expert in doing gear ratio calculations.I agree with you Tom, I like it when someone posts on old threads, and really like when someone replys. Jerry ever thought about you may not get a reply because of your profectinist addatude? seems you got to be right about everything. You have a nice bike, but seems you whant everone else to copy you................Curt
