throttle ?
Discussion in 'Motorized Bicycle General Discussion' started by barbk, Nov 30, 2010.
  1. barbk
    barbk New Member
    Aug 28, 2010
    I just got my bike back from having motor installed, i notice under carb it is leaking, do i need to adjust this? Throttle handle is so loose it could come off, do i need to adjust cable and tighten nuts, bolts on handle?, could someone direct me to an article or some help, i appreciate it. I rode it 5 miles, now more issue.
  2. Hammond Egger
    Hammond Egger New Member
    Oct 23, 2010
    270
    If it's new you're going to be doing a lot of adjusting. The carb should not be leaking and the throttle handle should not be loose; however the two are probably not related. What engine is it. Grubee sent out some defective throttle cables with their GT5 motors. The cable is about and inch too long for the housing.
  3. IamTheBear
    IamTheBear New Member
    Oct 6, 2010
    77
    really i think i got that inch to long cable on mine had to adjust it all the way out and still 1/4 turn before i catch, barbk if it is a new cns carb big red air cover they have a tube on the bottom that leaks like that it's normal from what i have read on here do not plug it up with anything
