Tightening the carb to manifold clamp, or the manifold to cylinder nuts -(2) Should not distort the carb. If you overtighten the top it can.
The screw on the side of the carb is an idle speed screw, so tightening that will make your slide stay way up there.
Are we on the same page? Also, make sure the slide is in the right way around.
