i need 2 replace the clutch side of the engine case on my not even broke in yet 66cc skyhawk gt5. can i leave the magneto and drive sprocket on and just change the case on other side. i have already taken off everything on that side?
Ummm make sure that you are using the correct (don't estimate) drill size for the tap. Here is a list of bolt sizes and what drill needs to be used. I like this chart as it list both US and Metric in ascending order together. Also use a thread cutting lubricant, you wouldn't believe how much it makes a difference. That is if you haven't.
