threadless & can't screw on my head please help?
izax
i need 2 replace the clutch side of the engine case on my not even broke in yet 66cc skyhawk gt5. can i leave the magneto and drive sprocket on and just change the case on other side. i have already taken off everything on that side?
Why is the clutch needing replacement? Awful early. But to answer your question, the clutch can be accessed from the right side.
After removing the clutch cover, the small screw by the star washer, and the star washer..lift off the flywheel, and...here you go...
http://s982.photobucket.com/albums/ae309/Ron-Becker/Clutch removal/
i tried to put a helicoil in 4 one of the head bolts & i over drilled. first the coil striped then when re-tapping the tap striped.
