jeffreykogan
Hi, does anyone know what the thread size is for the shaft bolt on the 78.5cc Predator clone for the Gasbike kit?
You can go to almost any hardware store and find that out. Just take the bolt with you.Hi, does anyone know what the thread size is for the shaft bolt on the 78.5cc Predator clone for the Gasbike kit?View attachment 106474
In case anyone was wondering, I went to home depot and was able to find out that the bolt size is 1/4-28Hi, does anyone know what the thread size is for the shaft bolt on the 78.5cc Predator clone for the Gasbike kit?View attachment 106474
I know, it surprised me. I thought it would be metric, but I guess notAn American bolt on a Chinese engine That's weird
I went to home depot, and the bolt fit perfectly into the hole marked 1/4-28. No play, and no unnecessary force needed.That's a Metric bolt, 8.8 is equal to USA grade 5
Home depot told you that bolt with 8.8 stamped on it was a USA 1/4" x 24 bolt?
Also, what metric size would it be then? I thought grade 5 only referred to the strength of the bolt.I went to home depot, and the bolt fit perfectly into the hole marked 1/4-28. No play, and no unnecessary force needed.
Is 7mm the same as an m7 bolt? I know this question might make me seem a bit thick-headed, but I'm definitely not an expert at bolt sizesWhat do ya think grade 8.8 means? Metric Grade strength numbers on a bolt means it's a metric bolt
USA bolts are not stamped with metric grade strength markings
Metric bolts are not stamped with USA grade strength markings
Go back to the store and see how it screws into 7mm
Yes it is though it could have more than one thread pattern.Is 7mm the same as an m7 bolt? I know this question might make me seem a bit thick-headed, but I'm definitely not an expert at bolt sizes
What thread pattern for an m7 would match up with a 1/4" by 28. The 1/4" by 28 seemed to have matched with the bolt that started this whole conversation, but the fact that you say that 8.8 is a metric bolt grade makes me think otherwise.Yes it is though it could have more than one thread pattern.
