cannonball2
After doing some of Quentons mods to my 2007 NE5 I was unable to get the stock 22mm carb to run clean. Not being a stranger to carb work having been in the lawn equipment business for years, I finally concluded I either have a bad carb, or the needle profile is all wrong. I could either get it to run well at top throttle, with a miserable low and mid range or vice versa. After 2 days I finally gave up and went for one of my favorite carbs a Tecumseh carb for a 5hp horizontial engine. Just happened to have one in stock. It took a couple of quick file strokes on the flange holes and she slid right on, installed the fuel line, fired it up and adjusted. The beauty of this carb is an adjustable main jet. After warming up it was out for a quick run. WOW! Smooth clean running all the way to the top. Not having the throttle linkage worked out yet I was having to operate the butterfly with my right hand. I let it go at 48mph, as I realized I really didnt need to hit the road. I am satisfied to say the least. Now it just a matter to make a small bracket for the throttle cable and a spacer to flow the Tecumseh into the Whizzer cylinder smoothly. The Tecumseh bore sits slightly higher than the stock carb. The stock air filter is pretty period correct looking also. This is a faily easy straight foward conversion. I believe I am finally going to be happy with the way the Whizzer runs now.
