Hey all. I just purchased a 2 HP Tecumseh engine with 4 mounting bolts (2 above the output shaft and 2 below). It also has a 1/2"? hex output shaft.
My questions are as follows:
Has anyone here mounted an engine like this and if so, do you have any pointers as to what kind of bracket to fabricate? It will be mounted in the frame.
Since I know little about these engines, will the hex shaft cause me any problems? I intend to mount a centrifugal clutch on it.
Thanks in advance for any suggestions you may have.
