colemanbales
Hey guys, i did a compression check on my engine today just because, and was a little concerned when i found that the engine was putting out 80psi. Now this sounded ok to me at first, but after seeing a video on youtube saying that these engines come stock with around 100, to 120 psi, i thought it would be good to get some feedback from you all. Now as far as the engine goes, the bottom end (including piston and piston rings) is brand new (only 1 tank of break in ratio fuel through it so far), but the head and jug (cooling fins, idk what their called really), are from my previous engine that i accidentally ruined the bottom end of. the only modification aside from that is i sanded the head with 400 grit sandpaper to make a higher compression head (i did this before even putting the engine together). does this seem right to you? will the compression go up once the break in is complete? thanks
