Rocky_Motor
I'm making an electric bike (circuits and all) right now and have been thinking about how I'm going to drive the rear wheel. I have a 1kw electric motor that will be mounted above the rear wheel. It spins to ~3000 RPM at 48 volts. It's rated for 30 amps at that voltage, which is 1.4kw.
I definitely don't want to use one of those rag clamps that come in the 2 stroke kits. So I was wondering what you guys think I could do? I've seen that maybe I could buy a disc brake wheel and mount a sprocket onto the disc brake bolt holes.
I have access to a machine shop at the school here. They have lathes, mills, welding, etc.. I've been using the mill and TIG machine a lot so I'm semi comfortable with those. Any suggestions are appreciated! I wasn't so sure about the disc brake hub method since the bolts are only like 6mm and electric motors deliver 100% torque from the start.
I'm not sure if this motor will pop wheelies or casually accelerate in such a circumstance. I'm doubtful it'll do a wheelie, but I guess that depends on the gearing.
