springer help
Discussion in 'Motorized Cruiser Bicycles' started by Smokey1981, Mar 12, 2011.
  1. Smokey1981
    Smokey1981 New Member
    Jul 9, 2010
    30
    ok i need a little help, im putting together a cruiser and i ordered an E-bay imitation schwinn springer and a generic criuser frame, i got the correct bearings for the frame/fork, But the problem i have is either the stem on the fork is about an inch too long or the neck on the frame is an inch too short. My guess is that the issue is with the frame being too short. i cant tighten the top nut down any further. can i just put a spcer on the stem between the bearing plate and the spring mount?????
    If i were to tighten down the nut on the neck it would bind up the springer really bad
    any suggestions???????
  2. joabthebugman
    joabthebugman New Member
    Jun 21, 2010
    347
    Yodar had the same problem
    We just bought another stem
  3. SlowBalt
    SlowBalt Member
    Mar 8, 2010
    759
    Take it to a good bike shop and they can add thread.
  4. KilroyCD
    KilroyCD New Member
    Jul 22, 2008
    279
    Many of those generic springers are made to fit both men's and women's bikes. The women's bike will have a longer head tube. I ran into the same thing you did, and I made a spacer. Shortening the steering tube was not an option as the top bracket for the spring would not reach the top of the head tube. I made my spacer using schedule 80pvc and it has been working fine now for two years. Here's a pic of my bike showing the spacer in place.
  5. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
  6. Smokey1981
    Jul 9, 2010
    30
    I decided to cut the excess off of the forks stem and rebend the bracket that mounts the spring to the stem it should work out just fine ill post up pix after its sorted. im also machining a pair of plates to kick the the front wheel out a litttle bit more
    sorry for the double post I was having issues with my computer locking up and forgot where I posted it up
  7. Smokey1981
    Jul 9, 2010
    30
    thanks kilroy I thought about doing the spacer but i didnt like the look.
    Nice bike btw i like the color
