spark plug ticking
Discussion in 'Motorized Bicycle General Discussion' started by ex-28, Jul 20, 2010.
  1. ex-28
    ex-28 New Member
    May 23, 2010
    110
    hi all my newphews bike was ticking 80cc kit from zoom , so i poped off the end of the plug and sure enough the metal inside the plastic head that goes on the sparkplug in there theres a little brass fitting that came out , i tried to screw it in again with a flat screw driver but it was stripped , so i unscrewed it and bought a new one (ngk) cut the wire 1" shorter so it had a clean end on it and screwed on the ew plastic head.
    it fits on verry tight to the plug , but at low speed he gets a bad ticking sound , i took the head off the wire again and the screw end of the head is scrweed in to the middle properlly as you can see it's right into the wire , anything else i can check to see whats making the ticking sound , i'm going to gap his plug later today and look at it today but not sure what else it could be.
    also the other end of the wire that goes to the cdi how does the wire come off of that end ? some say it unscrews just like the other end that goes to the plug but i tried and it didint seem to want to budge.
    this is the kit from zoom bicycles 80cc slant head
      File size:
      6.8 KB
      24
  2. grinNbarritt
    grinNbarritt New Member
    Jun 4, 2010
    54
    Could the piston be hitting the plug tip?
  3. ex-28
    ex-28 New Member
    May 23, 2010
    110
    nope not that at all i checked head its all clean ! :)
  4. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    The plug wire just unscrews from the CDI. Sometimes there's a bit of glue on them but with a little careful effort they all come out.
  5. ex-28
    ex-28 New Member
    May 23, 2010
    110
    ok dokie thank you
  6. Bikeguy Joe
    Jan 8, 2008
    11,529
    shoot it with some wd-40 or similar, it will come right out.
  7. ex-28
    ex-28 New Member
    May 23, 2010
    110
    his head bolts were loose all fixed now ,, heh
