My plug is tight as well, fuel goop runs down the head. Could it be that the crappy stock plug just can't burn all the way? I have an NGK (b6hs) and new boot coming. Will this solve or at least alleviate the problem?
The short answer?
Replacement may alleviate the problem.
Longer answer.
Welcome to life dating a chinagirl!
Ain't they cute?
I LIKE 'EM!
Yet they do have their faults.  Imagine that!
Everything is suspect!
The plug could be on the wrong end of the tolerance scale, the crush washer could be trash, or trashed, or the threaded sparkplug hole could be on the big side of tolerance, or beyond tolerance, OR, the seating surface for the sparkplug could be machined poorly.
Take your pick!
Fuel mix should NOT affect leaks from the top of the cylinder.
..and I say, 'should not' !
( Years back I learned that the graphite oil Arco once marketed WOULD DEFINITELY find EVERY tiny flaw in ANY gasket on an engine.)
....and you can take THAT to the bank!  lol
That stuff could make ANY engine look like absolute trash in just a short time!
...and 24;1 is ok for the first tank of break-in mix...  slim it to at least thirty to one, and forty to one is probably better for any chinagirl using some sort of modern mix oil designed for two stroke use.
50 for the good oils, and I have not tried Opti2, but I'd like to !!!
and of course, the top of the cylinder to head mating surface could be wonky, or the head gasket, itself.
By golly, I hope that helps!
rc
