I searched for ages but did not come up with an answer..
New china 50cc installed ,I had issues getting the cluth to engage so I could free wheel the bike but got it sorted . Now when I fired it up the clutch makes a mild screaming noise & when the pull the lever to engage the clutch its screams like a mofo & with the clutch locked on it still trying to drive I can't work it out . I adjust the flower nut loose & tighter btu no change tighter its worse looser & the clutch wont work at all .. I did notice a white grease type stuff on the friction pads is this normal ??? Could it be my clutch push rod as there not a lot of clutch arm movement & its hard to pull aswel..\\thanks in advance
