I don't own a chain breaker and I never grind the pins. I use a 3/32" punch with the pin centered over a small socket, center the punch on the pin and give it a solid whack. The pin will drive right out and can be reused if needed. Yes, it takes care to get the punch centered and held securely against the pin but it can be done. You'll want a short punch. It should only be long enough to drive the pin all the way through. The longer the punch the harder it is to control.
As for the OP's question about his current chain slack of 1/2" and the need for a tensioner based on that; the chain will wear and that 1/2" will increase. Without some way to tighten it you'll end up with a loose chain that can/will cause you troubles. It can even hurt you if it comes off or binds at speed.
As for brakes: I'd have saved the money you spent on that carburetor and made sure the bike will stop before adding performance parts to make it go faster. Brakes are nothing to scrimp on or take for granted. They can save your life.
Thanks for your input Tom. I'm going to work on my brakes some more with my Dad, and maybe adjust my spokes a bit. My brakes were functioning pretty decently prior to installing the engine before removing everything off of my handle bars, so I'm gonna try giving them an adjustment again. I'm just guessing that my brakes feel shot due to a lot of combined factors, but they still may be okay.
So as for my sticking throttle, do you have any particular suggestions on how to trim it? I don't know how I can shorten my cable without losing the stoppers on each end of them (One in the carb, one in the throttle handle bar.) Maybe I can invest in a new throttle, the one that came with the kit is plastic and feels like its going to break.
EDIT: I figured it out! I opened up my carburetor and it came to me! I just needed to stretch my throttle spring and re-assemble. I did, and even with the extra 6 inches of slack in the throttle line, it pulls itself back into the closed position fine!
I'll just have to scrounge some money up to finish this project. I'm in no real hurry to get it up and running.
