ridingpistonbroke
I removed the head gasket and put a paper thin one
on there,and did some flow porting on the inlet manifold
and exhaust.the only thing i bought was a dremel but
i needed that anyway so it doesn't count.
Anyway,after doing some reading on porting and port timing i thought
i better do the "porting" to the bits away from the cylinder. i have to ride
this thing every day and cant really afford to stuff it. a bit of grinding
for some flow shouldn't do any damage,the raised compression is a gamble
i have chosen to take. you can see in the first photo,the exhaust on the
left has a black oval shaped mark,and the inlet on the right with a light
oval area around the centre. this is obviously where the ports of the motor
are hitting.
I took the dremel with both a grinding and a sanding wheel and took as much
as i could on the exhaust, and really opened up the inlet.to the width of the pipe.
gave it a sand inside while i was at it. love the dremel. lol. all my gaskets i make now are from
leather i tore off an old sofa,works great. i have other gasket material but its
really for thermostat housings and smells like burning jb weld when its hot.
with a hole punch and some scissors you can go nuts with a foot of material.
i have run the leather on the inlet for 3 weeks riding evreyday to work,no dramas.
after there where cleaned up-
The head gasket itself that i made is an alum can,also cut with scissors and
hit with the hole punch.i didn't get a photo of the gasket before i put the head on,
but it was as simple as tracing out the old one and cutting it out. when i took it
out it started easily and runs noticeably smoother when it's cold,usually its a she-dog.
took a while to warm up as it does, but even when cold it definitely runs better.
when it warmed up it definatly felt stronger,top speed was the same though.
i only had a short ride, but i am taking it out again this afternoon,make sure
its good to take to work. i had to tighten the head bolts slightly more than
i did before but she should be right.
i did the work this morning, in about two hours. cost $0.
hopefully i have gained some power and not made a grenade out of it.
next is a expansion chamber,maybe a pocket bike exhaust. my exhaust has been
slightly modified, but its pretty ordinary in every meaning of the word.
the hi-tech head gasket material-
will update after a proper ride. comments welcome good or bad.there are some
more photo's but im limited in one post.
[I DO NOT RECOMMEND DOING THIS, IF FOR SOME REASON YOU DO, AND THE
PISTON CLEARANCE ISN'T ENOUGH AND YOU HAVE PROBLEMS,THAT'S YOUR
OWN STUPID FAULT.I TAKE NO RESPONSIBILITY] just in case someone says "yeh bro you said it would work"
cheers.
are hitting.
cheers.
