N naronmyo New Member Jul 30, 2023 2 2 3 38 Jul 30, 2023 #1 It’s reviving up high and my wheel is spinning like I’m hitting the throttle so I tightened it and it quieted down but the wheel still spins Reactions: fasteddy
Greg58 Well-Known Member May 1, 2011 5,353 2,575 113 66 Newnan,Georgia Jul 30, 2023 #2 Welcome to the forum, it sounds like you need to lower the idle or the clutch is not releasing. Reactions: Sidewinder Jerry and fasteddy
N naronmyo New Member Jul 30, 2023 2 2 3 38 Jul 30, 2023 #3 Greg58 said: Welcome to the forum, it sounds like you need to lower the idle or the clutch is not releasing. Click to expand... I lowered the idle but how do you get the clutch to release? Reactions: fasteddy
Greg58 Well-Known Member May 1, 2011 5,353 2,575 113 66 Newnan,Georgia Jul 30, 2023 #4 Most clutches have springs that make them release, you may have to take a look inside to see the problem. Reactions: fasteddy
Greg58 Well-Known Member May 1, 2011 5,353 2,575 113 66 Newnan,Georgia Jul 30, 2023 #5 I would try rolling the bike back and forth without the engine running, maybe that will make the clutch release. Reactions: fasteddy
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Mar 20, 2008 7,281 1,834 113 Los Angeles, CA. Jul 30, 2023 #6 Does the clutch spin nice & free when the engine is turned off? If so?, there's nothing wrong with the clutch & you simply need to lower the idle speed a little more. If the clutch doesn't spin nice & free when the engine is turned off?, then there's something stuck inside the clutch. Reactions: Sidewinder Jerry and PeteJ
Sidewinder Jerry Well-Known Member Dec 19, 2011 2,019 977 113 62 Rockwood, TN Jul 30, 2023 #7 It's help to know what kit/engine you had installed. Reactions: Venice Motor Bikes
