Snapped Rear Mounting Studs (3rd time!)
Discussion in 'Motorized Bicycle General Discussion' started by motorizedmatt, Sep 13, 2010.
  1. Chalo
    Chalo New Member
    Aug 10, 2010
    78
    The amount of eccentricity that causes tight and loose spots on a fixed gear or single speed bike is usually not even visible. You'd express it in tenths of a millimeter at most. But if the tight spots are too tight, they can cause noticeable resistance in the pedals, break axles, wreck freewheel bearings, etc.
    If you must have runout in your drive sprocket, bias the chain tension towards looseness, so that it does not tighten excessively at any point in the wheel's rotation.
    Chalo
  2. kipharley
    kipharley New Member
    Jul 9, 2009
    647
    I use nyloc nut's where ever there isn't a heat source,Also try green lock-tite on all assembled threaded connections.chain guard,fender braces,crank arm nuts,ect ect.Kip.
  3. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    Yes Kip thats a good idea with the nyloc nuts, I also use them and as the jam nut, I put a standard nut on first and then I put the nyloc but behind it and jam it tight against the other, these never come lose on mr ever, and I also put loctite on both as well but I use the blue.
  4. DudeZXT
    DudeZXT New Member
    Jun 20, 2010
    115
    I had the exact same thing happen with 3 bolts and ended up having to drill & tap new holes into my engine.
    I put the bolts in with no other mounting hardware and matched everything up, on the side, and realized that my bolts were a few threads too long to pull everything together tight. I also realized that a torque wrench set to 50~75 in/lbs. is tighter than I had done with my hand (I had been afraid to tighten them too much for fear of stripping/breaking things with my gorilla grip).
    Make sure your bolts are the right length (won't bottom-out without pulling everything tightly enough) and a torque wrench is highly recommended!
  5. kipharley
    Jul 9, 2009
    647
    Blue locktite will work just as well as the green.The green is for already assembled parts.It penitrates
    like WD-40.Kip.
  6. mapbike
    Mar 14, 2010
    5,380
    Thats cool, never used that before, but sounds like it could come in handy for some situations. there ya go you just learned me something I was not aware of....! LOL
    Shan
    dnut
  7. kipharley
    Jul 9, 2009
    647
    "OH BOY" Do I get a Gold Star? Glad to learn ya sompin! Kip.
  8. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    No, no - green Loctite is for "I never ever want this to come apart ever again." There is no place for green Loctite on these machines, let alone red. If you're going to use any at all, blue is all you should use.
  9. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    Most common reasons for studs to break are..
    Cheap Chinese studs... I change out ALL to grade 8.8 About the same as US grade 5.
    Incorrect mounting...mounts to both seat tube and down tube. Need as close to perfect fit.
    I use RED locktite on all studs (if removal is desired heat is needed).
    Proper torque 6mm 50-70 INCH pounds... 8mm 150-204 INCH pounds (I use 50 and 150)
    I double nut with a nylock nut as the second one.
    Here are some pictures of my mountings, I have never had a nut or stud, come loose, break or strip out.
    Proper mounting...
    [​IMG]
    I make these shims in order to get the proper torque. The nuts are too close to the clamp for a proper socket fit. I don't have a nylock nut on this illustration.
    [​IMG]
    I make this "L" bracket to eliminate engine twist due to engine torque. This way I don't have to over tighten mount nuts.
    [​IMG]
    Almost every bike frame needs a custom made front mount. The proper angle for the optimum mounting is 75 degrees.
    [​IMG]...[​IMG].......A bought mount can be had
    #29 Al.Fisherman, Sep 15, 2010
  10. Al.Fisherman
    Sep 9, 2009
    1,966
    [​IMG]
    Shims can be used between the rear mount and engine case.
    [​IMG]..[​IMG]
    #30 Al.Fisherman, Sep 15, 2010
  11. kipharley
    Jul 9, 2009
    647
    Green loctite works just fine.It certainly doesn't "weld" the two parts together.Kip.
  12. donutguy
    donutguy New Member
    Feb 4, 2010
    230
    Try grade 8 bolts, but I bet your frame will break before the grade 8 bolts do...especially since you drilled a hole through the frame.....not good-keep an eye on that area. I'm sorry that ain't more helpful but that hole would scare the heck out of me.
  13. kicking
    kicking New Member
    Apr 11, 2010
    403
  14. kipharley
    Jul 9, 2009
    647
  15. kipharley
    Jul 9, 2009
    647
    You may also try peddling more at start-up before you engage the clutch,when you do release the clutch slowly.That's where most of your torque is coming from.Kip.
  16. kicking
    kicking New Member
    Apr 11, 2010
    403
    I could not find the thread on boring out an hole to an little larger bolt size ; then filling the hole with hard material such as marine tex which I have used or . I may try the alumaweld stuff too. here is one good thread and I am sure there are more . http://motorbicycling.com/f3/no-more-broken-studs-bolts-me-11691.html
    I am having the same problem , I have my motor on the bench right now and "will fix it :
  17. kipharley
    Jul 9, 2009
    647
    I might try running a 6mm tap into the mount and access the threads to determin whether or not they need messing with.If you think they're sloppy enough maybe you should look into heli-coils.
    If my advice makes sense use it,if not use your best judgement.Kip.
  18. mapbike
    Mar 14, 2010
    5,380
    Go and buy you a 1/4 - 20TPI Bottoming Tap and a stick of 1/4"X20 all Thread rod or just get some grade #5 or #8 Bolts that are the correct length and run the 1/4"-20 Tap into the existing 6mm holes after putting some thin oil like 3 in one oil or something simular so that the tap will not seize while retapping the hole out from the 6mm to the 1/4, just remember to run it in (the tap) 2-3 threads in depth at a time and then back out and then back in again repeating this proccess until the tap bottoms out in the hole, unscrew tap out of hole and then spray the hole out with either brake cleaner or carb. cleaner to get the alum. shavings out and then you are ready for your new 1/4" studs or bolt which ever you choose. very simple proccess use a small cresent wrench to turn tap if you dont have a tap wrench and make sure it is running straight into the hole.
    #38 mapbike, Sep 22, 2010
  19. kicking
    kicking New Member
    Apr 11, 2010
    403
    I have the short cut to this thread bike ,, in case im online ,,, i will paste it on my reply to the next person ,, snaped studs ,,, happens an lot !!! and i have learned ... do not use stainless steel too .... thanks ,,, P.S I wanted to send my motor back after the stud broke .... but this site tells me it happens a lot
    #39 kicking, Sep 22, 2010
  20. Kinskeys
    Kinskeys New Member
    Jul 13, 2010
    33
    I broke mine too and I retapped it to 8mm, so far so good.
