Slipping Clutch
Discussion in 'Motorized Bicycle General Discussion' started by jtgolden, Aug 2, 2011.
  1. jtgolden
    jtgolden New Member
    May 31, 2011
    110
    My clutch on my 66 is slipping. I have taken off the clutch cover and tightened the flower nut and that has done nothing. I have been trying to fix this for days now looked all over on this forum and have found nothing. Anyone had this problem and tightening the flower nut never worked for you, what did you do to fix?
    Thanks for the help!
  2. azbill
    azbill Active Member
    May 18, 2008
    3,367
    where are you ???
    perhaps a member is close that can assist in your dilema ;)
  3. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Did you lube the gears on the right side of your engine? Often people over lubricate them and the excess grease gets onto the clutch pads. You can try cleaning them with automotive brake cleaner, usually sold in aerosol cans at the auto parts store.
    The gears only require a very small dab of grease. Anything more and you can have the problem you describe.
    Your clutch cable isn't too tight, is it?
  4. jtgolden
    jtgolden New Member
    May 31, 2011
    110
    Im am located about 60 miles south of St Louis. I checked and cleaned the pads, the next step I was going for is to switch the pads out of my other motor. If somone could help would be awesome, the cable length is good and I may need to ad more grease Il try that.
  5. The Busted Nut
    The Busted Nut New Member
    Aug 2, 2011
    96
    clean it with rubbing alcohol.
    Follow these steps:
    1. engage clutch
    2. Push the clutch plate against the pads and tighten the flower nut. Then turn it 2 more notches.
    3. Put the screw back in the hole and fire it up. If it is still slipping, you may want to buy new pads
    let us know what happens .shft.
  6. jtgolden
    jtgolden New Member
    May 31, 2011
    110
    Im going to switch the pads, to see if that works, thing is the motor has only 50 miles on it so could they be bad already? I did have chain lock up and then this started.
  7. The Busted Nut
    Aug 2, 2011
    96
    Can some1 verify this for me?
    Could the spring in the clutch be bad?
    On another note, make sure the clutch is closing all the way. If it's not then pad won't help.
  8. jtgolden
    jtgolden New Member
    May 31, 2011
    110
    Alright guys I finally figured it out, I wasnt pulling the clutch in when I tightened the flower nut. After pulling it in I could get the nut tighter. This is worked for me.
    Thanks for your help guys and gals
  9. The Busted Nut
    Aug 2, 2011
    96
    That's what I freakin said!!!!
    Jk at least it's fixed.
  10. jtgolden
    jtgolden New Member
    May 31, 2011
    110
    Shout IK i saw that information, thought that it was in the thread on how to adjust your clutch. Well your the one who helped me fix this thing. Thanks The Busted Nut you were a big help!
