mr.charlie
I don't think it should make any difference. The combustion chamber is over the center of the piston whether it's an angle head or straight head. The spark plug electrode is in the same place either way.
i have to disagree with regards to the electrode bein in the same place..the only way to verify that would be to mark the plug in relation to where the tip of the electrode is open (unshrouded) because no 2 plugs are rarely the same due to the threads of the plug itself and where the plug hits bottom with in the threads of the head...try it...take one plug and mark it then thread it into a "hemi head"..... and see where the sharpie mark is ....mark the fin on the head or the chamber...now take the same plug and do it to the "angle plug head".....then take a completely diff plug and do it again......the electrode position changes in relation to where the threads were cut on the plug's and where they were cut in the head's
there is gonna be a difference between the 2 heads just because of the way the plug hole is bored into the casting..and heres why...take the 2 heads and set them on a bench..look at them from say the right side (chain guard side)....the "hemi" has the plug seated at 12 o'clock.....the "angle" has the plug at 1 o'clock...that right of the bat is a 30 degree difference in position of the plug.....now look at both heads from the front...if you screw a plug into the "angle" head where does the unshrouded part of the electrode end up?....12 o'clock facing the top of the chamber.....6 o'clock facing the exhaust port and aiming at the dome of the piston?... if its 3 or 9 o'clock its off to the side no?...which is my point about flame travel of the ignited plug......now with the "hemi" head the electrode can be rotated to any degree so to speak...but the electrode will never get closer to the piston surface....the easiest analogy i can think of is how the earth changes its axis with the change of season's...(i hope that make sense)......now does this all make a difference..i dont know....but in theory by useing the indexing method you can an should be able to tailor the spark flame pattern..especially since were not talking about a multiple spark discharge cdi ignition system........this once again is in theory.........
in order for the plug to line up at the same point in every head the boring tool for spark plug threads would have to start at the same position on each and every head...and the same goes for the assembly of the spark plug itself the electrode would have to be afixed at the same point in regards to the start of the threads........
