wezwheels
the design is and has a flaw. the way the plug sets in the head causes an over heating of one side of the piston top. the plug does not fall in at top dead center. an unequal heating of the piston top causes a weld splatter effect over time. the piston top is getting hot on the one side and not distributing the heat over the whole piston. which starts a melting or a splatter of the metal on the top of the piston. the splatter builds up and causes it to gouge the cylinder and piston. the gouging has lead to the splatter getting down to the rings and jamming the rings in there slots. before you ask or tell yourself i`m and idiot, the oil ratio is a 16/1 to a 20/1. the denso plug is equal to the ngk b6hs. so its not a hot plug or a lack of oil that caused the issue. just a poor design? or am i missing something? you decide? thanks again. wez.
