SCSW tuned pipe & carb $150
robin
These are performance parts for the 2 stroke which iam parting out because my HT engine seized
$150 for both see pic of pipe.trk
What is a SCSW tuned pipe? is it specifically made for the HT engine? do you have a link that I can get more info about it?
Thanks!
Drew
SCSW pipes are made at Pipelyne Manufacturing. Dean (the owner) has been making two cycle pipes for 30+ years. We've tested 6 different pipes and this pipe worked the best "hands down" The pipe design came form BZM's 50cc race pipe. The header pipe was extended a few inches to help with the low and mid range. It comes with a heat shield so it doesn't get hot. The carb is a pulse carb not a gravity fed carb. It's easier to tune and there's no need to change jets or move the clip. It has a high and low jet screws. If I remember correctly. I had my L screw set at 1 5/8 turned out and the H at 1 1/4 turns out.
thats a nice pipe.
is it for the 49cc or the 66cc engine? how loud compared to stock?
tell me more about the carb.
The pipe is for both engines--it depends what stinger (the muffler on the end) you use as to how loud it is--the one pictured that i will supply is louder--i also will supply a stainless steel thermos bottle packed with stainless steel wool that makes it quieter than the stock.
interesting, so how much of a performance increase do you get with this pipe? also, please do tell more about the carb.
