Runs fine but no power
Appliancedoc
I have one of those kits bought on ebay. At first it ran good, after a while it has really slowed down. I have replaced the nt carb for a "performance " one thinking i had a carb problem. It runs down the road alot slower than it used to. It starts and runs normally, i just dont have the speed i used to. Suggestions?
crassius
4,032
155
USA
bummer as that is easiest to fix - now, you'll need to go thru whole list of possible leaks, and muffler clogs, and spark gaps, and cylinder wall appearance, and compression test, etc.
Venice Motor Bikes
Mar 20, 2008
6,608
416
83
Los Angeles, CA.
How are you mixing your gas & oil?
Was there any specific thing that you noticed the engine doing right before it lost power??
Appliancedoc
Im mixing 20-1 using lucas 2 cycle oil. It didnt do anything different and that is what has me stumped. Although i would like to upgrade from this engine after i have resd up on whats available out there. I commute to work every day on this and would like to run 35-40mph. Any suggestions on what to buy that i dont have to spend a fortune on?
Appliancedoc
I just read some other posts that people are mixing 40-1 & even 50-1. What is the mixture you have found that works best? Will mixing 20-1 really result in a power loss like this?
