supposedly the spark plug is supposed to aim at the intake side so the mixture combusts faster, but i don't think it really matters.
it shouldn't be offset, though. that sounds like a defect, but it shouldn't really hurt it, i guess.
The only thing a slant head does is clear the frame better. Sure the heads inside combustion area offers better enhanced compression even it is not the right shape. You basically have is just that. A bit o better compression. I got a billet aluminum head from Manic Mechanic. It is the slant head variety.
While I have not used it yet . So I have no input about its performance. I would rather of had a plug going in in the center. His billet head the combustion chamber does looks way better than anything china has offered though. The overall shape inside is what it should be for what it is and is very good looking in person. With that said it is better than a china slant head. The slanted spark plug has no performance enhancing value that I can see.
I'm only 2 1/2 minutes from the store now,,I have to get one of those heads lol
Besides improved performance, Jim's heads look much better in all aspects simply put. Keep em coming!
I'm pretty sure you could run the China slant heads to the left or right as well...would sure look strange however!
And you might hit the plug and wire with your knee !
Salty
i removed my head to fix a problem and notice the spark plug sits not center..but off center...does it make any difference if it sits closer to the intake side or the exaust side...i had read it doesn't ..so for looks i have the spark pug over the carb...
*squish band: a narrow section of a combustion chamber in which the fuel charge is more compressed by the piston than in the rest of the chamber; designed to help direct the flow of the fresh charge and to improve scavenging
