Kristof
Hi, i am trying to use digikey for parts.
I am having trouble finding diodes.
Diodes, Rectifiers - Single | Digi-Key
radio shack has just redid all their stores. they are more DYS friendly.
they have many diodes & rectifiers in stock.
Can you post pics of both sides of your PCB, so that I can look and see how it looks?
Here it is. I haven't had a chance to test it yet, and I'm still trying to figure out a good place to mount it on my bike. I'll be running this to a CR80 coil. Wish me luck, as this is my first attempt at anything like this and thanks again rohmell for all your help. What's funny is that I finished the simple CDI plans just in time for the retard circuit to be posted. I'm sure with a little modification, I can get it adapted to this as well. Here are some pics. The capacitors were so big that the only container I could find that would work was a travel container for a bar of soap, which I have to paint to match...
My resistors are 18 and 82 ohms and 1/2 watt each. Is that not right?
That right the color tripped me sorry
Hey Rohmell for all the work you have done and are still doing, I did some work for you today. Opened my original Grubee GT-5 CDI box and here are some pics. Someone with your savvy and test equipment should be able to trace things out and get values for most components. Can't read the components because of the epoxy but it sure looks familiar to me from following this sticky. The covering on the cap came off with the epoxy. You can see half of the cap covering stuck to the coil. On the PCB I can see the scr, a diode, and a resistor and can easily guess which way the other components go. The PC board didn't have any epoxy stick to the bottom and I have tried a few combinations of the numbers in internet searches but no luck yet. If you would like to see this stuff for yourself feel free to PM me with your mailing address and I will shoot it off to you. My equipment for electronics stops at my DVOM and my soldering irons hehehe. Anywho, hope this helps.
The caps came in the mail all I need is a 18ohm and a 82ohm resisters
so close ! my Dad told me he has some old radios and a vcr he's going to drop by the house, so maybe there will be one or both in there- radio shack didn't have them and the supply shop is in the next county![]()
My capacitors i was waiting on came in the mailbox today
Enough to make 5 CDI boxes
I'll make one tonight and pick up the ignition coil on the weekend if i get time.
If all goes well i'll be more than happy to pass on my 4 spares![]()
is it possible to use a car's Ignition coil ? rather than one from a dirt bike >?
