rear suspension #2
Curved manifold. What I did on my first build. Put the air filter in line of airflow. I think that bike would look good with a larger mb tank like a 1gal
Yeah 01.. thats why i was thinking peanut tank.I saw a small one looked alright. Ive a 'Neanderthaw motorcycle salvage i'll check see what they have. So far i'm gonna use the Honda g100. No issues with it. I can make a curved manifold and it will low and clear the shock and da leg!
Thats what 'gasbike' calls their NT carb. My pz 16 will now fit nice with a curved mani and have room for cone filter. I need to find the ole 'filtron' sock for this set up. How you comin along on your next build? I was thinking of tryin to turn a freehub into a 3or four gear. Yoy can get a freehub kit with only one gear for a fixie set up.. so im thinking with the spacers yoy get..i could add my own gearing. Idn. It does look like it was squeezed
Gas tank is mounted..no rack hanging off the back..this just fell into place.
Made the filter cover template.. need a real piece of filter..like the ole filtron stuff.
Gonna run the stock muffler for now. I need a sharp 90 to make a pipe. Which will happen because now the shock girder has only 3/4" before hitting the muffler. I tkink this will be the last of the surprise changes to make.
That is one out of the box brake set up! No wonder why you have faith in your front coaster set up. Dang that is a clone fer sure. Looks just like the Honda. Hey I wanted the Briggs. The mind conceived, but the hands missed the mark. I could put an angled mm plate over the existing and make it work. So if the power isn't there ill be redoing it. I'm in holding, waiting for a #35 sprocket,and freewheel from sbp. I thought I could use a sprocket freewheel from a razor mx500.. nope..their threaded uncommonly, they go on halfway, then you gotta wrench'em on..and I didn't want to chance striping my adaptor. Al ready thinking of a build using a cruiser frame and running down tubes like jeff's bikes (CCC).
Having problems...try later..ok..those are just boots on the forks. I want to paint them ...but ..with my rattle can paint jobs it wont last long..so
Looks great! Super clean work!
Like the rear fender stay. I built a bobber out of a Sportster and did the same thing, makes a really sturdy mount.
You can paint the chrome if you cut the plating well with coarse grit and prime it. I kinda like it as is though. Boots are a cool touch!
Wow..thx guys!! What a great place to come share how this "hobby"has taken hold of me. I always liked white..just hope i will take care of it..it doesnt hide dirt an grime like black does. Yeah the chrome will stay. The boots did it.
Well. Movin along..waiting for a Staton delivery. Fender brace turn'd out nice. I'm wondering how a half fender would look in front..starting behind the triple to keep stuff off me and the engine..any idea's??
You got a classic bobber now with no front fender.
Any part of a front fender will help make riding easier/more enjoyable.
I rode my Sporty bobber 60mi in the rain at 38 degrees. Cold wasn't the worst part it was the completely full western boots from the water distribution system(read front wheel). Ate my share of gravel and sand too. Add the fender at what ever size.
Im tapping out on rear suspention. The clutch i ordered ended up being a max torque design. I thought i was getting the C spring design..not. The shudder take offs are intensified by the suspension movement. Soo i have a bicycle. One last attempt at saving it will be to put a belt drive with lever actuated clutch. It works nice on my daily driver. The draw back is having to use a dual pull brake. If anyone has done a long handle lock unlock lever on a belt clutch..how'd ya do it?
