Hello i recently purchased a raw racer 2 and now I cannot get it to pull in order to start it. I installed a pull start and it becomes impossible to pull after the 1st 1/2 revolution.
Heres what I have already checked. I took spark plug out then motor pulls freely. Next Threaded a shorter spark plug in and its impossible to pull again. The engine is new and has never had fuel into it and no fuel lines are installed. I took exhaust and carb off and tried to pull and it was still impossible to pull. I have also taken off clutch plate and tried these things. I made sure crank key was good and made sure head on correct and arrow on piston is oriented correctly
My question is can the motor build up pressure in the crank case or head and keep the motor from rotating. Is there a pressure release valve or reed on the 100cc raw racer that might be bad.
