I want to try to rig an electric motor to a mountain bike as a hill helper. I'm hoping that I won't use it except to help with the hills because I want to try it first hooked directly to the mt bike drive, and of course it will prolong the battery life, and give me some much needed exercise.
I bought a junker mt bike. It had all the sprockets but the shifters don't work which is fine. I may switch the rear wheel for a coaster wheel anyway. My question is about gearing and speeds.
desired performance.
speeds of 12 to 15 mph
motor to be used as helper for the hills only.
geared for maximum torque.
motor specs 3000 rpm
12 amp motor.
24 volt
sprocket 1 15/16 diameter 11 tooth.
bike has three sprockets on the crank. several on the rear but probably will be a coaster with a twenty inch wheel. I could leave the mt bile wheel on if it will help.., It is 24"
so motor to chain on which sprocket.... small medium or large...
chain to rear sprocket on which front sprocket.
Im more interested in torque than speed.
setup with controller and throttle so I can vary the rpm of the motor.
summary.
motor to which front sprocket...
chain from which front sprocket to which rear sprocket.. should I replace the 24" wheel with a 20"
I have a about a week to decide before the bike sprocket arrives for the motor.
12 amp motor.
24 volt
summary.
