Finally got my new motor broken in (about 250 miles) and got carb and jetting pretty good so I decided to go ahead and do some porting for extra power. Now my goal was to increase top end power without losing to much low end. I wanted to raise the exhuast port to get more top end but I was afraid to go too far so I only raised it about .6mm and enlarged the rest of the port by about .4mm.
I also added a second bottom gasket to further raise the ports.Then added a super thin .2 cooper head gasket. I basically just filled out the intake(40mm) to make it round and polished it smooth. I also filed down the part of the piston that was covering the port at TDC.
The result was crazy bottom end and midrange power. If I open the throttle to much when I start it up it nearly throws me off the bike and accelerates hard to about 6k rpm where the power seems to steadily drop and I can reach 34mph at 7500rpm with a 26 inch wheel and 38 tooth sprocket.
But it takes a looooooooooong time to get from 30 to 34. So my question is where did I go wrong on the porting? I know that the result I got is ideal for cruising and reliability and the motor pulls strong and runs really smooth but I want more top end and I live in an area where all the land is flat and I don't mind pedaling to start.
