Back to report that the 6 mm studs did not work out.  The JBWeld pulled out the first time I went to tighten it.  So I bought 5/16 inch all thread and retapped the block for that.  Then I took a 2 inch 1/4 inch pipe nipple and cut it into 4 pieces of about 1/2 inch to make spacers to get the 5/16 nylock nuts elevated above the fins on the head.  Grabbed the all thread with a vise grip just below the head and torqued to 100 inch pounds (Dax says the 6 mm bolts need 85 inch pounds).  Took it for a spin today and it started real easy.  I have converted the friction drive to a Dax chain drive because my Armadillo tires were giving off crumbs of rubber from the friction drive.  Now all I need is a good break in.  This time I am using Opti-2 at 36:1 ratio so my new piston does not seize up like the first one did by using 72:1.  Looks like the 5/16 all thread will do the trick on the head.  Pictures attached.
