piston question
Discussion in 'Motorized Bicycle General Discussion' started by alvelez61, Jul 3, 2012.
  1. alvelez61
    alvelez61 New Member
    Jul 3, 2012
    25
    hey, just got my 2 stroke engine, i was surprised that the piston was not installed, is this common, or am i special....thank you guys for this forum
  2. Len455
    Len455 New Member
    Mar 11, 2012
    144
    What??? Lol i think your speical. Did you buy it new? Did it come with the piston or none at all?
  3. alvelez61
    Jul 3, 2012
    25
    yes, brand new, all the parts are there, just caught me off guard.. i got an assembly list.. for the piston and i noticed that all i have to do is make sure its facing the right way, there is an arrow on top of it,
  4. DaveC
    DaveC Member
    Jul 14, 2010
    970
    Who did you get it from? When many of the companies claim a "10 minute run-in" that would be hard to do without a piston. These kits are supposed to bolt on, no assembly of the motor.
    There could be a whole bunch of kits like this and a few Chinamen LTAO at us Americans. C'mon, these are people that put plastic in their milk to raise the milkfat count and paint our toys with lead paint. They are a pretty funny bunch:rolleyes:
  5. alvelez61
    Jul 3, 2012
    25
    i got it on ebay , seller called flamcomann, i have no complaints, i was just surprised at this, the parts look good, they did furnish instructions on this assembly, but ur right about the 10 min slap on... pistons have to be installed correctly to say the lease
  6. BigBlue
    BigBlue New Member
    Nov 29, 2011
    781
  7. alvelez61
    Jul 3, 2012
    25
    thanks bigblue
  8. biknut
    biknut Active Member
    Sep 28, 2010
    6,365
    Perhaps the piston was removed to get around EPA, since what you bought wasn't a running motor.
  9. MotorBicycleRacing
    Jul 28, 2010
    5,690
    30
    Have never heard of an engine being sold in pieces.
    Was it a one off sale or are there more available?
    There is no ebay user named flamcomann
    Do you have a link to the auction?
    How much did you pay for an unassembled engine?
    #9 MotorBicycleRacing, Jul 4, 2012
  10. nightcruiser
    nightcruiser New Member
    Mar 25, 2011
    1,180
    Hmm, unassembled? That's a new one on me...
    Assuming it was just the top end, that shouldn't be a negative as long as the motor was protected from debris getting into the bottom end and you have the basic skills to assemble the top end... Most experienced builders pull the top end on a new motor anyway, for inspection and removal of debris that is all too often found in the head...
    You probably got the top end assembled already, if not, it's pretty easy. Most important thing is you need to take note of the opening in the rings and the small pins in the piston slot where the ring openings go. If you compress the rings in the wrong position you will break them, we dont want that to happen cause you will be stuck waiting for parts...
    Speaking of waiting for parts, the head studs (all the studs on the motor) are usually pretty weak and crappy, SickBikeParts.com sells nice stud kits for not too much money. IMHO its better to build your bike with solid studs rather than letting the weak ones break on you and then having to deal with that situation. There are a couple different size studs, so make sure you order the right ones for your motor if you decide to upgrade them...
    I set my studs into the block with red loctite, then use blue loctite when I put the nuts on the head. Red is stronger than blue, so the head nuts should spin off before the studs spin out... That said, I probably wouldn't use red loctite on the factory studs, cause they are bound to break and I wouldn't want to have to extract them from the block with red loctite on them. I also use red loctite on the intake and exhaust studs when I install them in the jug, then blue on the nuts. (I would probably refrain from using the red loctite on factory studs here as well) The vibrations on these motors make everything come loose, unfortunately aluminum is weak and threads strip out easily, so you can only torque things down so much. The loctite helps keep everything tightened up and torqued down properly.
    With the studs in place and everything nice and clean, assembling the top end is pretty simple. I put one e-clip in place on one side of the piston, you should see the slot where it fits, make sure it is seated properly, then slide the piston pin through the other side. Install the needle bearing in the crank arm and apply a couple drops of 2-stroke oil to it, then put the piston over it and push the pin through till it hits the installed e-clip. The arrow on the piston should be pointing in the direction of flow in the engine, that is, from the intake pointing toward the exhaust. Now install the second e-clip, which is probably the toughest part....
    When installing the jug I first lube the piston, rings and jug wall a bit with some 2-stroke oil to make things easier, then aligned the rings so they mate with the pins in their respective slots. I apply a thin layer of gasket sealer on both sides of the gaskets then slide the jug down to the piston. Compressing the top ring with my fingers I was able to get the first ring into the jug, slide it down to the second ring and do the same, it went pretty easy for me. Then work the piston up the cylinder a bit so the rings don't slip back out and carefully work the jug down into place.
    Now you've gotta install the head gasket (I use a thin layer of gasket sealer on both sides) and then the head, and then torque the whole thing in place. The whole process kinda needs to be done in one shot without too much delay, cause you need to torque that head in place before the gasket sealer starts to set.
    You can skip all the finer points if you like, like better studs, using loctite, gasket sealer etc, and just throw the jug on there and torque away, but chances are you will be revisiting it down the road, or at least having to torque again, and agian... but if you do go through all off the trouble to do it right she should hold pretty solid and not develop air leaks etc on you down the road....
    #10 nightcruiser, Jul 4, 2012
  11. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,502
    50
    Wow BN! That would make sense.
  12. alvelez61
    Jul 3, 2012
    25
    thanx nightcruiser
    the engine comes pretty much in tac, just the top has to be installed, the instructions are simple and to the point, pretty much the way you specified, except the locite, i appreciate your valuable info, just have to wait for the rings, already ordered them...
  13. alvelez61
    Jul 3, 2012
    25
    my appologies m.b.r, i spelled the name wrong its called flamencomann south carolina, i guess he is a small time seller, all the parts were there, pretty much clean, the only instructions were for the piston instalaltion, i won a bid for 101.00 plus 17.00 shipping
  14. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,502
    50
    That is a sweet price!
