Oversize frame mounting bracket
raneyd
Doug in Wyoming
I have a bicycle frame that is oversized (larger diamater) than the 67 cc motor is designed to mount on. The motor fits the seatpost down tube fine but the front mounting tube is larger. I have seen these brackets from time to time on ebay but none are listed right now and I want to build this bike asap. I know that I could drill the frame and mount it that way but don't want to risk drilling and not getting it exactly square.
Can anyone help me locate a source for the brackets made to mount the standard motor from China on a larger front tube?
Thanks for the help.
pretty simple actually if you have a drill and small piece of 1/4" steel and a u-bolt and a 5/16" drill bit! and make your own!
drilling thru the frame is never a good idea.
you COULD get some threaded rod of same pitch as mount studs, make them about 2 1/2" long. thread them into motor. pry them apart and set motor into frame. squeeze them back together.
flatten front mount a little. install mount, nuts, washers.
grind off excess rod.
I don't know if I'd use that method. bending the studs while in the motor will most likely break it.
EEK! Drilling holes in a frame is Never a goog idea. That down tube supports not only you, but the front end as well. If it breaks your day gets MUCH worse! Don't drill the support tube. :eek:
I've drilled mine and nothing bad has happened in the year that I've been riding it. Its a swhinn made in china to boot so I'm riding on the edge. I would have welded in a tube where I drilled the frame but so far I've not found spary paint to match the bike so I ride it like I've stole it.
I wasn't too hot on the idea of drilling the frame but so far its working the engine was a vey tight fit in the frame there is a close up of it on pictures and videos about page 6 of Norman's bikes pictures if you want to see it.
